新選擇:HM-801Portable Player Preorder
文章Hkimo 發表於 週三 8月 26, 2009 12:30 pm
昨天找線時,偶然發現Headfi上有人提到的機器.
高貴的售價,但是相比於現行市面上的產品,或許又會是一個新選擇.
重點是amp模組可以更換以及擁有高階的解碼,放音,USB DAC以及多檔案的資源度.
我想唯四的缺點就是外型,太重,吃SD以及耗電了吧!!
但往好處想,除了IPOD+IQUBE,IMOD與PCM-D50以外,又多了一個高貴的選擇(USD$600.00). :mad:
Features
Modular Design: Modular Amplifier Bay (Named GanQi Bay) and 14.8 volt Lithium Polymer Battery Bay
Memory: SDHC Card
DAC function: Coaxial (44.1kHz, 96 kHz) , USB DAC (16bit, 48kHz)
DAC Chip: Burr-Brown PCM1704U (for Player, Coaxial and USB) ; Op-Amp: OPA627
Size: 114 mm *78mm * 25.5 mm or 4.49 * 3.07 * 1.00 Inch
Output: Headphone out; Line out
Exchangeable Module Battery Life : 7 to 8 hours (Depending upon which Modular Amplifier board is mounted)
Charger and External Power supply: External Power supply also acts as a bettery charger and can deliver Hi-Fi grade sound quality even while charging.
Accessory: Lithium ion polymer battery; Charger/External Power Supply (110-240VAC, 50-60 Hz); USB cable; RCA-to-Mini adapter for digital coaxial input.
Music Format Support
APE Fast、Normal、High Mode
AAC 16K-320Kbps
FLAC lossless VBR 44.1kHz and 24bit 96KHz
WMA 8-355kbps
OGG Quality 0-Quality 10
WAV PCM,MS-ADPCM,IMA-ADPCM
Opamp: OPA275
Input Voltage: +/-7.5v
quiescent current 6-7ma
Input Impedance: 20k
closed loop voltage gain: 6dB
Distortion: 0.002%
S/N: 102dB
Frequency: 10Hz - 60KHz (-1dB)
Maximium Undistorted Power Output (RMS)
32 Ohm 1.5v 70mw
150 Ohm 3.4v 77mw
320 Ohm 3.8v 45mw
Maximium Current
32 Ohm +24ma -30ma
150 Ohm +15ma -16ma
320 Ohm +10ma -11ma
MP3(VBR) 8-320Kbps
土製炸彈般的外觀.
讓人聽不厭的內在.
這是我的隨身系統.
但我要擔心的是,
那一天在銀行拿出來,會不會被警衛注意報警呢??
Hkimo
註冊時間: 週二 12月 28, 2004 12:36 am
Re: 新選擇:HM-801Portable Player Preorder
文章brettracco 發表於 週三 8月 26, 2009 12:43 pm
Preorder 所以預購價是usd $600, 上市後價格是 $700以上 :mad: :mad: :mad:
而且HIFIMAN是不是對岸的品牌 :?:
轉貼IMP3.NET的介紹|:
 Head-Direct是一家主要致力於國內耳機、功放、線纜等聽音設備海外銷售的公司。其銷售的產品除了自有品牌Head-Direct產品外,還包 含YUIN、OVC、VSONIC、Fiio、Darkvoice等多家國內品牌產品。近日Head-Direct在知名耳機發燒論壇Head- Fi.org開展活動,為即將上市的一款另類便攜播放器HiFiMAN HM-801推出預訂優惠活動(據Head-Fi.org管理員jude稱,Head-Direct正在將其自由品牌變更為HiFiMAN)
 HiFiMAN HM-801設計理念有別於常見的便攜播放器產品,以高音質為追求目標。HiFiMAN HM-801採用模組化可更換設計,備有放大器及電池更換艙。銷售版本標配放大器和14.8V鋰離子聚合物電池。後期則會隨發展而更換放大器和電池配置, 並公開資料讓用戶自己選擇配置。主機沒有內置快閃記憶體,採用外接SDHC卡進行存儲。數模轉換器來自TI旗下Burr-Brown的PCM1704,運算放大 器為TI OPA627,兩者均很少用於便攜播放器產品。
 據稱HiFiMAN HM-801設計耳機輸出功率為100mW(16Ω)、64mW(32Ω)、40mW(300Ω),可輕鬆推動諸如森海塞爾HD580、AKG K240DF等高阻抗耳機。
  HiFiMAN HM-801外形尺寸為114×78×25.5毫米,重2000克。支援同軸(44.1KHz)和USB DAC(最高96KHz)輸入,耳機輸出及線路輸出。電池續航時間6-8小時,會因採用的放大器模組不同而變化。可外接電源充、供電。充電時仍可收聽音 樂。標配鋰離子聚合物電池、電源適配器、USB線及迷你同軸適配器。
  HiFiMAN HM-801支援的音頻格式:
  AAC 16K-320Kbps
  FLAC、WMAlossless VBR 44.1kHz (will support 24bit 96KHz via softerware upgrade in the future)
  WMA 8-355kbps
  MP3(VBR) 8-320Kbps
  據稱HiFiMAN HM-801將於6月份上市,銷售價格將在700美元以上。在Head-Fi.org的預訂價格為600美元。Head-Direct表示,將捐獻10% HiFiMAN HM-801銷售額給Head-Fi.org網站。
brettracco
註冊時間: 週二 12月 16, 2008 9:45 am
文章ack1029 發表於 週三 8月 26, 2009 1:45 pm
話說亦軒上面有個東西也很有趣
hi Audio 【AMP3Pro】 個人隨身音響系統
http://www.mingo-hmw.com/forum/viewthre ... a=page%3D1
如果照它的敘述 應該也是很有趣的一台系統
混和播放機+耳擴功能 價位上應該也是版友能夠接受的感覺...
恰巧看到亦軒也捐錢給台灣風災了... :mad:
耳罩:HFI-780
耳道:佛心TF10...
ack1029
註冊時間: 週五 2月 22, 2008 3:54 pm
文章donthuang 發表於 週日 9月 13, 2009 3:52 pm
第一批出貨了 (好像只有三台)
http://vaiopocket.seesaa.net/
比想像中的輕,聲音和市面上的隨身音樂播放器明顯不同等級
比站長自己先前使用的iRiver ihp140 > iBasso D10 的聲音還要精緻大氣
donthuang
文章: 39
註冊時間: 週日 2月 12, 2006 3:34 pm
來自: お米屋さんダイナミック
文章gameguy 發表於 週日 2月 07, 2010 6:14 pm
身為台灣第一個自己改IMOD的人,當然精益求精目前預定跟"头领科技" 聯絡看這玩意怎麼買,目前裝都裝上OPA627怎麼看了很多評論,好像沒發揮出OPA627的實力,怪了看來還是需要拆下去看裡面怎麼佈線的。
PCM1704配OPA627威力發不出來,怪哉怪哉(拆下去看就知道怎麼回事了)
最後由 wgundamcustom 於 週二 2月 09, 2010 1:56 pm 編輯,總共編輯了 1 次。
理由: 請不要在文章前後加奇怪或無意義的字串
繼續創造傳奇的耳機,看頭像就知道是哪一支耳機了 :)
gameguy
文章: 820
註冊時間: 週六 5月 10, 2003 10:44 pm
文章hdd60311 發表於 週一 2月 08, 2010 12:07 am
話說對岸好像把這台叫成"高保真男人"...... :ho:
hdd60311
文章: 39
註冊時間: 週五 8月 21, 2009 3:57 pm
文章Arashi 發表於 週一 2月 08, 2010 11:37 pm
801日文發音ya o i
應該有人看得懂.... :haha:
訊源-MR1、MGR-A7、MZ-RH1
耳姬-SE530、ES3X
Arashi
註冊時間: 週五 10月 02, 2009 3:49 pm
文章hdd60311 發表於 週二 2月 09, 2010 12:14 am
看不懂.....懇請解答 :?:
hdd60311
文章: 39
文章Arashi 發表於 週二 2月 09, 2010 6:54 am
hdd60311 寫:看不懂.....懇請解答 :?:
boys love (光速逃)
耳姬-SE530、ES3X
Arashi
正在瀏覽這個版面的使用者:Bing [Bot] 和 140 位訪客
