METASONIX TM-4變成訂大帥哥的小管機
這台很有趣
雖然規格實在普普
但是長相我倒是很喜歡
METASONIX製造的全世界最小台真空管擴大機TM-4
此擴大機每聲道用一支6BM8,每聲道提供1瓦的功率
配有兩個耳機接孔與喇叭輸出孔
可以帶著旅行在每個你落腳的地方
也能夠建構精緻的桌上小系統
規格:
Power output: approx. 1 watt peak into 8 ohms per channel at 5% distortion.
Max input sensitivity 0.2 volts for full power output.
Frequency response +-3dB, 70 Hz to 35 kHz.
Power input 10v AC to 12v AC, 50/60 Hz 1 amp at idle--derived from an appropriate plug-in AC adapter.
Use of an AC adapter to suit local AC mains power allows use of the TM-4 anywhere in the world.
Inputs: separate phone jacks for audio; unit includes RCA-to-phone adapters.
Outputs: two headphone jacks, 1/8" and 1/4" phone, plus separate phone jacks for each speaker output.
Dimensions: 7 1/2" (192mm) x 4 3/8" (112mm) x 3" (77mm).
Weight not including accessories approx. 5 pounds (2.2 kg).
哈哈
修改一下標題
以符合後續發展:D
音響跟劇場,都是一種虛擬性的真實:P
由 阿毛 於 09/23/2002 01:38:36 修改
由 阿毛 於 09/23/2002 13:24:46 修改
